Utility Pole Foundation
Can STTAD software be used for designing the foundation of a utility pole structure?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Utility Pole Foundation
What type of foundation are you designing? I'm assuming you have a drilled pier. I've always designed those using IBC Section 1805.7. This section has a fairly simple procedure that checks the soil pressures against fairly conservative assumed values. Then you just design the reinforced concrete pier for the combination of moment and axial load. Drilled piers are pretty simple to design under normal soil conditions and loading.
