NX8.5: Flickering work area under Linux 64bit
I've been lent for a period a copy of NX 8.5 for Linux 64bit. I installed it under Arch Linux 64bit, which is up-to-date, and when I launch NX issuing at the terminal "$UGII_ROOT_DIR/ugii" the splash screen appears and I get into NX.
However, the rendering of the GUI is really bad. Menu names, for example, don't appear until I hover the mouse over the menu bar. The general appearance is quite dull, but I suppose that's because NX is using Motif as graphic toolkit. The worse is that the workspace, where modeling should take place, flickers at high frequency when I move the mouse inside of it, and sometimes it doesn't even display a workspace, just a grey area. If there's something modelled inside, rotating or panning the view also causes the same flicker and I would get succesive superimposed images showing the different positions the model had while rotating/panning it. The console shows no errors at all.
As you can imagine, it's impossible to work with it. I've checked the options and all seems right. I will give you the specs of my machine, hoping that someone can shed some light:
OS: Arch Linux 64bit, with LXDE+OpenBox
Processor: AMD Phenom II X4 960T
RAM: 8GB
MoBo: Asus M5A78L-M LX
VGA: Only the built-in Radeon HD 3000 (RS780) using OSS radeon drivers from official repos
Thank you all in advance,
César
RAM: 8GB
César
RE: NX8.5: Flickering work area under Linux 64bit
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
An ex-classmate of mine wants to start a solo project for engineering consultancy, specially for cast iron. He has experience with Catia, but since he's short on budget he wants to use an Ubuntu-based workstation. He has little knowledge of Linux, and he knew I use Linux, although not Ubuntu (I use Arch, as mentioned before). He gave me a 45 day trial of NX and asked me to test it.
Anyway, since I couldn't make it work, I told him it could be due to my poor graphics card, or the fact that the software is made for Suse or Red Hat.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
https://www.plm.automation.siemens.com/en_us/about...?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Remove .nx85 directory from your home and restart the application.
