Break Out Section line width
How can I change the line width in break out section view? When I change width before break out sectioning it changes nothing.
RE: Break Out Section line width
NX 8.5 version
Did you try printing it on a sheet of paper to see if it prints out with the line width that you want ?
...or viewing the drawing in monochrome display?
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
I've exported it to pdf. The breakout line width is the same with standard line. I use 0.18mm for standard lines and I want to use 0,13 for breakout lines. I've drawn the spline and changed width to 0,13 and it's correct in printing, but when I made the break with that spile the width has changed.
If you right click the view (Style/Visible Lines) and change the width it updates properly for the break-out view.Is there something i am missing here?.
Best Regards
Kapil Sharma
