Drawing Templates NX8.5: view scale not respected
I have developped my drawing_templates.pax and it works but the view scale is changed from 1 to 1/2 when used.
How to fix the scale ?
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Drawing Templates NX8.5: view scale not respected
Hi Didier,
Will it make any difference if you change the view scale in the template .prt file?
Best Regards
Kapil Sharma
Hi Kapil,
I don't understand your question. The scale is 1 in my template.prt file and to test my .pax file I use the same master model, so I don't understand why the scale becomes 1/2 !!!
Didier Psaltopoulos
Hi Cowski
Thanks a lot, it works well
Didier Psaltopoulos
Hi Didier,
Sorry i misunderstood your question initially.
Best Regards
Kapil
Hi Cowski,
The method works well, but It would be nice to have a program to set the boundary to automatic rectangle for all views after.
Does anybody can developped this simple program ?
Thanks in advance.
Didier Psaltopoulos
