Wall Tie or Veneer Anchor?
ACI 530.1-05 has a section for wall ties (3.4.c) and another section for veneer anchors. The maximum distribution for an adjustable "wall tie" is 1.77 sq. ft. (3.4C-4a); the maximum distribution for an adjustable "veneer anchor" is 2.67 sq. ft.(3.4D-4). What is the difference between a "wall tie" and a "veneer anchor"? For example, Wire-Bond Series 600 Ladder Adjustable Tab is described as a "... Tab & Wall Tie", but the "ties" certainly act as a veneer anchor.
RE: Wall Tie or Veneer Anchor?
Attached is a BIA publication on unit ties.
I guess that we are moving up in the world as things get more crowded, including the wall ties. :)
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
