Save as new revision, skip numbers
Is it possible to save a part revision 01 directly as a .05?
Or do I have to do it one at a time?
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: Save as new revision, skip numbers
I'm not sure about you intend. Could you explain about your exact requirement?
It is not possible to do like that...But you can delete the revisions once you created it if you want to see only 01 and o5.
Manik
Shoot for the moon.
Even if you miss, you’ll land among the stars.
That's what I needed to know. Thanks!
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Setting the revsion level of a file copy should be an option within TeamCenter. If not, open an IR and request that as an enahncement.
In many cases, you are bringing existing parts into a system that may already be at rev 5. Why should you have to revise the part 5 times and then delete files to get it there. FYI: Windchill allows us to set the revision when we save or copy a part just for this reason.
Ben Loosli
