How to diffuse high pressure 15,000 psi to 0 atmospheric pressure from a equipment
A pipe contains water at 80 Deg F , pressure inside the system is 15,000 psi, if the pressure has to be released (atmospheric pr), but still needs to be conatined inside a closed chamber before releasing out on ground. How would I achieve this? can someone help.
RE: How to diffuse high pressure 15,000 psi to 0 atmospheric pressure from a equipment
Let the flow proceed through a restrictor like the Lee Bender Jet:
http://www.theleeco.com/JETWEB2.NSF/5ba5409b0cab73...
Close the valve.
Open another valve that vents the chamber to atmosphere,
and a third valve that drains the chamber.
Let the chamber drain.
Close all valves.
Repeat until the pressure is fully relieved.
Mike Halloran
Pembroke Pines, FL, USA
The Lee restrictor is rated for up to 5000psi?
Ppatel1, Oops. Don't use the stock Lee part.
Do call and ask about a special, reinforced for your pressure.
What I described amounts to a DB&B manifold. It could have a special geometry allowing insertion of interchangeable throttling orifices, or it could have a needle valve or a capillary to do the throttling.
Or, if your valves are sturdy enough and open slowly, maybe you don't need a restrictor other than the valve.
Mike Halloran
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
