Stainless Bolting
Stainless Bolting
Hi
I was wondering if anyone could give some advice on what is the best stainless bolting material for long term subsea use in a CP environment. Basically I am required to bolt to a M20 female threaded component made from 431S29 (UNS S43100). I was thinking of using the same material but was unsure of its performance subsea. If I was to use another grade of bolt the female thread would still be 431 and I am most likely stuck with this anyway. Any advice would be much appreciated.
Thank you.
Thank you.
RE: Stainless Bolting
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Steve Jones
http://www.standard.no/PageFiles/1194/M-001.pdf
