Customer Defaults - Subtracted Body Preview
Does anybody know the customer Default (Or just the location of the option) to turn off the ghost viewing of subtracted bodies.
Ie, if I shell a box, then hover over one of the shelled walls, it shows a "ghost" preview of the original form of the box. I believe this was a feature introduced in NX8, but not 100% sure.
Thanks in advance
Adam
Thanks in advance
Adam
RE: Customer Defaults - Subtracted Body Preview
You are correct as far as i remember it started from NX8.
You can go to preferences/selection/ and turn off HIGHLIGHT ORIGINAL as shown in the picture attached.
Best Regards
Kapil Sharma
Do you kow if there is a customer default that will turn this off on start up, or will i just have to de-select it everytime. I've searched through the defaults, but am unable to find anything under selection (unless it has been locked by the site admin)
However, if you toggle this option OFF, 'Dialog Memory' will remember this setting from session to session, until you decide to toggle it back ON.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
