ASME SA928 PIPE
ASME SA928 PIPE
I know this has been a previous topic !
However I Urgently need Design Code Data:
Tensile, Yield, Sa, and St.
I only have ASME B31.3 : 2010. Not listed in that issue.
Regards Mike
Regards Mike
RE: ASME SA928 PIPE
The minimum tensile strength is 109 ksi for grade S32760 and 90 ksi for S32205.
It would appear that Code Case 2637 would apply for grade 32205 for ASME VIII, Div. 1 applications. Max allowable stress values are:
100 F 27.1 ksi
200 F 27.1 ksi
300 F 26.2 ksi
400 F 25.2 ksi
500 F 24.6 ksi
600 F 24.3 ksi
RE: ASME SA928 PIPE
However I am still having problems.
ASME A928 UNS S31803 (welded) Is not listed in
ASME Part D Materials
B31.3 : 2012
I desperately need the data for
Tensile
Yield
Sa
St
Regards Mike
RE: ASME SA928 PIPE
RE: ASME SA928 PIPE
thanks for your reply.
Sorry but I cannot see S31803 data above, only S32760 & S32205
To my knowledge these are not equivalents.
The following are required
Tensile
Yield
Sa
St
Can you post the data sheet, or give the URL where it can be viewed?
Regards Mike
RE: ASME SA928 PIPE
RE: ASME SA928 PIPE
