Force-constrain a parallel dimension?
Is there a way to constrain dimensions in sketcher to specific geometry?
The blue dimension in the attached image is what I want to achieve. The blue dimension should be parallel to one of the sketch lines.
NX8.5 Win7SP1 64bit i7-3770K@4.3Ghz 16GB Quadro2000
RE: Force-constrain a parallel dimension?
I checked with the drafting application, and sure enough, there is a button labeled "Direction" in the Edit Dimension dialog where you can define the direction of the dimension. This is exactly what I need in the Sketching environment, but when I switch to that environment the Direction button is missing from the Edit Dimension dialog.
Hi CNSZU,
you will find simmilar option in PMI also.Will check with our experts and let you know if i am missing something.
Best Regards
Kapil Sharma
Yes, I guess adding reference lines to help with adding correct dimensions is a doable workaround.
