boiler blowdown
boiler blowdown
boiler blowdown
why boiler blow-down?
RE: boiler blowdown
The purpose of boiler blowdown is to control the concentration of dissolved salts in the boiler.
The dissolved salts concentrate in the boiler when the boiler water evaporates to steam. The salts do not evaportate with the steam, the salts remain in the boiler water. Without control of the salts, the boiler heat transfer surfaces would eventually scale as the concentration of salts rises to the level of salt precipitation.
RE: boiler blowdown
any build up of material listed above plus scale and sediment.
RE: boiler blowdown
to prevent supersaturation of bad salts in the water. These salts will eventually deposit and scale up plus cause chloride damage, so dump it out.
