Link a macro to our templates?
Can I link a macro to our templates?
We currently, open old documents > system options > document properties > load standards > units > change units > close > file save...
I am looking for something that our users can use to short cut this process. So, I was thinking if I had a macro linked to the new formats (templates) there would be a button to be used on older documents.
I hope someone has an answer.. Thank you
RE: Link a macro to our templates?
One of those should do the trick.
I think mac_copydoc migh tbe your best bet.
Thoughts:
-Can I record a macro and link it to a template?
-Build a button and embedded that into the template as well?
-Record macro using templates, save macro in the same folder as the templates?
I hope I am not thinking way out side the box..
-Has any one used the record macro?
-Has anyone done this?
looking for some direction.
maybe i need to jump and try it.
If you can shed more details, I may be able to help you with the macro.
Deepak Gupta
CSWE, CSWP, CSDA
SW 2012 SP5.0 & 2013 SP 1.0
Boxer's SolidWorks™ Blog
SolidWorks™ Rendering Contest
I have been running Macros and tried to make my own. However when I run them, my SWX crashes so I have called our VAR and have almost given up. I have a few more options up my sleeve I will keep you up dated.
Deepak- are you involved with SWXgeeks?
Yes I'm one of the member of the SWGeeks.
Deepak Gupta
CSWE, CSWP, CSDA
I am as well..
Deepak Gupta
CSWE, CSWP, CSDA
