Pilecap Design
Pilecap Design
Pilecap Design
Any sample manual calculation for pilecap design?
RE: Pilecap Design
Try the CRSI manual.
RE: Pilecap Design
You can perform your design at the most critical cross sections using the loads obtained from the analysis.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
RE: Pilecap Design
tq so much !
RE: Pilecap Design
why a lot of example for truss analogy method shown until 4 nos. pile group only? how about 5 nos. pile group and above? not suitable to use the truss analogy method?
RE: Pilecap Design
Truss analogy (strut and tie) methods work for any arrangement of piles. The reason why you haven't found any examples is probably because it gets a bit cumbersome as more loads are introduced to the model. You can't use a cookbook for everything.
RE: Pilecap Design
If you don't understand how to do this, or how to use the example provided for your situation, perhaps you consult another engineer in your office.
Qshake
pipe
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
