Is anyone familiar with Clamp Bolt standard?
Gentlemen,
I hope this is the right forum to ask question about fastener.
On the enclosed picture I circled Clamp bolt. Does anybody know International/national/local/factory standard (or at least some sort of "cheat sheet")that regulates such fastener.
The idea is not to re-invent the bicycle, but to be able to order one using standard designation/part number, or to make one that is, at least theoretically, interchangeable with bolts already out there.
Thank you in advance.
RE: Is anyone familiar with Clamp Bolt standard?
That appears to be a lawn mower part. I am not aware of anything like that as a standard.
JHG
Giving how much screws and bolts on the “special” page looked like off-the shelf items, I’ve had some hope.
Also, I am in possession of very similar piece coming from different industry; so there might be some recommendation, something from textbook or manual, not the real standard.
Nevertheless, if nothing else pops out, negative result is result as well.
I thought that page was from bicycle catalog, not lawnmower.
Actually, the bolt starts looking more and common
But those were either conically tapered, with the "bite" taken out of the shaft, or cylindrical with a tapered face.
I Googled "Scott Bonnar", and I found lawn mowers. "Bottom blades" could make for an interesting bicycle. Maybe they make salami slicers, beard trimmers and Ben Hur chariots as well.
I never thought about what we called bicycle king pins. As MintJulep notes, they are tapered, and I don't recall a circular chunk out of them.
JHG
On the good side, I can just design the heck out of this bolt to my liking!
http://store.buckchuck.com/scroll-chucks-adapters/...
