Copy parts with constrains.
In a assembly i'm using a few parts with always the same constrains between them.
Is there a way to copy those parts WITH the constrains between them?
Now i select the part and use the MOVE command withe the COPY function ON. But this is not possible with the constrains between them so i have to set the constrains many times again.
Making a sub-assembly of the parts is not what i want.
Has anyone a answer?
Thanks already.
Thanks already.
Using NX 8.0 on Windows 7 (64)
RE: Copy parts with constrains.
You have open an ER like I've done.
Thank you...
Using NX 8 and TC9.1
Tanks.
