Welding Aluminum Structures to Galvanized Steel
I have a situation where I am connection aluminum handrail to a galvanized HSS tube, therefore a welded connection is the better option. However, once they make that weld to the tube and the galvanizing has burnt off wouldn't the connection be susceptible to galvanic action again? Would cold galvanizing or painting the connection be enough to prevent this? I feel like this must be more of a common issue then I realize because think of all the aluminum guardrails that are fastened to edge beams or edge angles. Thanks in advance for your help.
RE: Welding Aluminum Structures to Galvanized Steel
Fusion welding aluminum to steel is not possible because of their different melting points.
( Shipbuilders bond aluminum superstructures to steel hulls by means of strips of aluminum and steel that have been detonation welded. I don't think detonation welding is possible for forms other than flat strips edge to edge, or maybe lap joints, so that process is probably not available to you. Please let us know if I am wrong. )
Mike Halloran
Pembroke Pines, FL, USA
Aluminum does not oxidize in the same manner as steel so it cannot generally support arc fusion as MikeHalloran noted. There are exceptions for aluminum-to-aluminum welding (GMAC process with appropriate shielding gas can be used), but not for aluminum to steel.
In short, you can't weld aluminum to steel or likewise.
don't do it !
if you Have to join them, weld a steel stub onto the steel, so that the Al tube will fit over it, and cross bolt.
Quando Omni Flunkus Moritati
Bolting is the most common, and only practical, way to do it. Be sure to place a bitumastic paint or other barrier between the aluminum and the steel.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
