How to run automaticaly a GRIP program just after opened a part file ?
I would like to run automatically a GRIP program just after opened a part file.
What are the all the steps?
Is it possible to have a sample!
Thanks a lot
SuperQuark
Thanks a lot
SuperQuark
RE: How to run automaticaly a GRIP program just after opened a part file ?
You may be able to do it with UGMenu customization and put the action of running the GRIP program after the Open command.
Another method would be to usee a user exit and use your GRIP program to both open the file and run your customizations after the file is opened.
Ben Loosli
Thanks for your reply . . .
I need to open some part files and I would like that attributes defined in the part will be set by the GRIP program.
So, I just want to click on the prt file to open it, and the GRIP program must be stated automaticaly after it was displayed.
In this way each time I open the part file the attributes were updated . . .
Could you explain me how I could make it ?
Many thanks in advance.
SuperQuark
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
At this time I work with NX6 . . .
Here some explanations that I really would like to make:
I want to extract strings from the drawing sheet attribute <W@$SH_PART_NAME>
Sample:
When I create a note with <W@$SH_PART_NAME>, the result is Cover_1234.prt
So I need 2 attributes (or expression) strings:
First one is : Title = Name ; Value = Cover
Second one is : Title = Number ; Value = 1234
How can I extract substring from <W@$SH_PART_NAME>?
SuperQuark
Long_note = 'This is a long note'
sht_note = substr(long_note,11,9)
sht_note will be 'long note'
The substr command takes your string, the start position and # of charcaters and returns a portion of your string.
Ben Loosli
I know the substr function in GRIP, but my question was how do you use it whith <W@$SH_PART_NAME> into NX as an attribute or as an expression ?
I don't find it, so it was for this reason that I thought to write a GRIP program.
I hope it is clear now . . .
Many thanks
SuperQuark
What are you planning on doing with the sheet name attributes?
Ben Loosli
I would like to extract the string COVER and the string 1234 and put them into attributes variables.
So, the result will be :
Attribute1 = COVER
Attribute2 = 1234
Then I will use it to fill in my drawing box . . .
TITLE = COVER (Attribute1)
NUMBER = 1234 (Attribute2)
SuperQuark
Search the string for the '-', then extract the beginning and assign it to the Sheet name attribute.
Uste the rest of the string for your partname attribute assigned in your format.
Ben Loosli
