Looking for typical drained shear strength values for CL
I have to do a preliminary levee design for a project, but the borrow source for the clay has not been identified. I have found typical values for undrained shear strengths, but I'm having trouble finding typical drained values. I don't anticipate any issues with stability (relatively short compacted clay levee on sand/ bedrock foundation with relatively flat slopes). However, I'd like to assume reasonable values for the sudden drawdown & long term analysis.
RE: Looking for typical drained shear strength values for CL
Lacking any other information, I would assume something in the 26 to 28 degree range.
Mike Lambert
Discount cohesion and you're dealing with 11 to 30 degrees, or thereabouts. . .
f-d
¡papá gordo ain’t no madre flaca!
