Expressions to turn off/on instances
Hi there,
Im creating a design tool whereby the 3D child part is controlled by 2D sketches from the top level through wave link and expressions. I have the ability to turn bosses on/off through a suppress by expression. This works by assigning each instance of the boss around the casing a name eq 1, 2, 3, 4..... N around the casing and then assigning each one an expression name to turn seperate bosses on/off.
With this I am limited to a specific number of bosses, is there a way to be able to change the number of bosses and be able to turn each one off/on seperately from the top level through expressions?
Any help would be greatly appreciated
RE: Expressions to turn off/on instances
I haven't tried it, but you may be able to set that number to zero . . . I know for sure that "1" works.
