Welding Machine Calibration
Are there any requirements in ASME Sec 1, ASME Sec IX, ASME Sec VIII Div 1, to welding machine calibration. First ASME audit coming up. Thanks.
Welding Machine CalibrationWelding Machine Calibration(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Welding Machine Calibration
None that I am aware of. Keep the welder continuity list handy, and have calibration records on any devices related to measuring/verification based on your Quality Manual. It should be straight forward. Good Luck.
See, in each of those cases, the company could be required to produce those records showing it was following its own procedures ... even though every welder and every supervisor knows they never have done so, and don't even have an ammeter in the building.
In practice, the weld current - which is the only thing that "could be" calibrated, is going to change every job with the tungsten thickness, electrde diameter, heat load, distance from the weld, feedrate, etc.
On newer inverter machines the digital instrumentation is generally quite good and there is really no 'calibration' possible or necessary.
Whatever else you do, set up a program and generate records.
