Move entity from model to sheet or sheet to model (change ms/ps)
AutoCad has the "change ms/ps" feature for transfering entities through the viewport.
I haven't found this in DraftSight yet.
I could copy the entities with a reference point in one space, then go to the other space (through the viewport or by switching tabs) and paste at the same reference point and scale them up or down, then go back and delete the original...
...but it's a lot easier to just click a button and pick the entities like you can with "change ms/ps". SO, has anyone found a command for this?
