Creating Reference set using journal
Hi
I need any one suggestion or help in regarding.
I want to run a journal, Which will create one reference set and will move all the components to the same reference set.
Example:
If I modeled an assembly which contains 20 sub assemblies. After completing my model I need the following with a single click. (If it is possible please guide me)
My Need:
I need a journal to create Reference Set name as "Assembly", after creating reference set it should move all the assembly components to the same "Assembly" reference set.
Thanks in Advance.
SaM
Example:
My Need:
Thanks in Advance.
SaM
RE: Creating Reference set using journal
thread561-307788: Use of Model Reference set in assemblies
thread561-308516: Best practice for assembly reference set
www.nxjournaling.com
