Framework around text
Is there a simple way to get a framework (cadre, square) around text in a drawing?
So far i haven't found a solution. And drawing a square around the text everytime is not a good solution for us.
Thanks already.
RE: Framework around text
create a sketch around your text
Perfect.
Thanks for the fast reaction and the solution.
Also for the rounded cadre, you can create a dimension with this cadre, the option is accessible through the Style.. menu and then adapt the dimension with Edit text function.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Thanks.
I can find the rounded cadre. But i can not find the way to adapt the dimension text itself. I can only find the way to adapt de "After-text".
But i don't think i need to adapt the dimension-text itself. That would be cheating......
