Cloning not rename constraints name
I've used the cloning tool to create a new project.
As you can see from the image attached, the new part name aren't equal to the related constraints name.
It's a bug or a missing setting ?
Thank you...
Using NX 8 and TC9.1
RE: Cloning not rename constraints name
sorry for the late response.
The problem seem to be in the code used by our programmers to use the clone command.
Thank you again.
Thank you...
