One way shear check for plate
For a slab model using plates, to check the one way shear capacity of the slab near the column. Program gives you Qx and Qy both with signs positive. Since its one-way check you won't sum up the two values to compare with (Phi)Vc for concrete?
RE: One way shear check for plate
