Wet steam expansion
Wet steam expansion
I believe this should be a straightforward calculation but it has been a long time since I've done this stuff and am having trouble wrapping my head around it.
I have one tank at equilibrium that is partially filled with 240C water at 33 bar (state 1). A valve is opened to a second equivalent sized tank that is empty. I need to calculate the final temperature and pressure once the new equilibrium is reached (state 2). The tanks can be considered adiabatic.
Thanks.
Thanks.
RE: Wet steam expansion
You have to write 2 equations
1 conservation of weight
2 conservation of energy
1 weight of steam(1) + weight of water(1)= weight of steam(2) + weight of water(2)
2 internal energy Of steam(1)+internal energy of water(1)=internal energy Of steam(2)+internal energy of water(2)
Best way I have found is to get v(T), u(T) from steam tables along saturation line so the 2 equations have 2 variables, T and water(2)
Might do it iteratively,by first assuming the steam pressure drops according to standard gas laws. Then find the incremental effect of the evaporated water.
Where is the outlet on the source tank? Is it below or above liquid level?
From this you could write the amount of water flashed to steam would be
(T2-T1)/hg*W
For example, if the expansion tank were equal to the original tank, then 1st iteration would change the temperature from 464F to 400F and
(464-400)W=1115delta W
deltaW=64/1115= .057
should be
deltaW=64/1115= .057W
Consider a volume of 1 lb of steam at saturated conditions 33 bar (465 F)
, you initial state. Let the volume of the expansion be V2=V1 the same as the volume,V1 (V1=0.947 from steam tables) of steam in the initial state. Let there be 2 lb saturated water
First assume gas laws for 1st iteration. Then, the new sat temperature is
400 F.
The amount of water flashed would be
447*W=373(W-delW)+1115delW=373*W+delW*(ufg)=373W-delW*742
delW=(447-373)*W/742
For W=1
I get
delW=0.097 lb
Now we have 1.097 lb steam which would have a specific volumne of
2V1/1.097=(2*.947)/1.097=1.586=vg
using steam tables, the new sat point is T=415 The new delW would be
delW=(447-391)/726W=0.077lb
vg=2V1/1.077=1.615
new T=413 F; p=287psi= 19.5 bar
Another iteration would get only slightly closer.
So many possibilities...
rmw
PS: but reading back through before posting, I guess Sailoday already ask all this.
Did the first tank, once opened, bleed saturated steam to the empty tank, or did it bleed water?
If it bled steam (or water), when was the second tank vented? Or are we to assume that the second tank - and now the first when they equalize - needs to accomodate that unvented air? (which will change the final pressure)
When the steam (or water) hit the second tank, what/how much (how large are the tanks with what wall thicknesses) was needed to raise the temperature of the second tank walls - we are told it (the systems ?) is adiabatic, so the text (probably) wants us to ignore the energy needed to heat the second tank (which must come from the energy in the sat steam in the first tank), but you can't really ignore it. I've bled too many steam pipes and turbines and drains for too long during cold plant startups to ignore that much water mass & energy & heat ... 8<)
A simple energy balance will yield Integral [hdm]= mu -(mu)i (1)
where h is stagnation entalpy of souce tank of exiting fluid, dm is decrease in mass of source tank
mu is total internal enery of receiver with i, the initil conditions in receiver.
If steam is vented from source tank, I beleive including quality will be difficult.
As a start
If saturated steam is being vented from the source tank
get steam table data for enthalpy vs pressure, say from 33 bars to 28 bars. If the variation in entalpy is small then approximate the above integral in (1)
Also if the receiver tank starts out with low pressure, again use steam tables and Daltons Law to approximate right hand side.
Yes--there are a lot of ifs.
