Hole Callouts reverting back to standard
Hi folks
I have a number of holes on a part where we have special instructions. Typical instructions include notes for adding a helical thread insert, bushing, etc. We add these instructions directly below the hole diameter by adding custom text to the hole callout.
We are doing this on hole wizard holes, so the hole callout tool automatically brings up the info from our hole callout file. In some cases we have customized entries, but for one-off instructions, we manually edit the hole callout.
Now, we've found that making any changes to the hole (diameter, depth option) in the 3D model causes solidworks to revert back to the callout from the standards folder, and erase the special instructions we manually entered.
It seems crazy that Solidworks would not simply update the elements of the note which need changing, and leave the custom data alone. Is there a way I can force SW to retain my information in a hole callout once I've entered it?
I'm using SW2012 SP3
RE: Hole Callouts reverting back to standard
Seriously, ISTR a discussion here about the difficulty of making changes/annotations to toolbox parts permanent or persistent. I think there actually is/was a nonobvious/ obtuse/ bizarre way to make SW behave as you wish. Try using the E-T site search function.
... and/or try the new "More Like This' button.
Mike Halloran
Pembroke Pines, FL, USA
The way that I have found to workaround this problem is to create the hole callout, then create a note and select the hole callout to link the value, add any custom text. then hide the hole callout note. If you want to see the note again,you can use the view\hide/show annotations tool.
Kerry
I'm interested in seeing more about this issue you are experiencing. However, first, I would like you to talk to your VAR to have them confirm what is going on in your scenarios. There may be a bug here, or it may need an enhancement request.
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
Where I see the issue arising is in the fact that when I go to edit the hole note text, SW even pops up a warning telling me that I might lose the link. I'm OK with that, since I can work out the custom hole note text on my own for my one-off case. Since this is a one off, I don't think it's justified to copy the callouts file, as this would require company wide changes to be pushed (per our CAD standards).
Where it gets to me is that modifications to the hole (granted these are done in hole wizard) don't update the parametric data pertaining to the hole. Its almost as though SW "erases" the hole and rewrites with the data from the callouts file. IMO it should remember that I took the extra step to make special hole callout definitions. Even if it "purpled" out the text to let me know something's changed and might be broken. I'd rather it do that than risk missing the helicoil or bushing spec at checking time.
