Assembly constraints using existing points
Why can't I create an assembly constraint which references an existing datum point with NX-8.0?
If I select other types of points ie. end point, mid point, or circle center there is no issue.
However if I try to select an existing datum point NX displays a alert "The point references an invalid geometry and cannot be used in a constraint.
Am I missing something? Has anyone else found a way around this issue?
RE: Assembly constraints using existing points
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I am working on a earlier release. NX 8.0.0.25
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
