Assembly navigator jumps to other monitor.
I use two monitors. I have placed placed my Assembly Navigator and Part Navigator on the second monitor. This worked good.
But since i have updated my graphiccard driver i have the problem that when i change between Sheetmetal, Drafting or Modeling my Assembly Navigator jumps from my second monitor to my main monitor. This sometimes also happens when i start using a other feature.
Sometime's it's the Part Navigator that jumps to the main monitor.
I updated the graphiccard driver because i had some other problems in NX. This problem is now solved.
Has anyone a idea how i could lock my Assembly and Part Navigator on my second monitor.
Thanks.
Thanks.
RE: Assembly navigator jumps to other monitor.
www.nxjournaling.com
That is the way it should work yeah. But i have replaced my Assembly and part navigator moch more time's.
But it's going better now. It's getting rare that the screens jump back.
So finaly NX starts to remember where i want to have my sreens.
I found out that there is a version of the videocard driver that is certified by siemens, but when i install that driver i have a almost black screen in negative image, so that one totally dosn't work.
Now i'm using the newest driver again but stil the screens jump back very often.
Has anyone maybe a solution for me?
Thanks already.
Using NX 8.0 on Windows 7 (64)
( slightly dangerous operation if one doesn't delete the correct data since everything windows does depends on the registry...)
Performing a complete uninstall + install will also ( Should...) delete the settings and create new.
Anyway, (important) No NX session running:
In the registry, browse down to Computer\HKEY_CURRENT_USER\software\Unigraphics Solutions\NX\ and rename the "8.0" to , say, "old-8.0". *
Exit the registry editor.
This way the next time NX starts it will not find the "8.0" and has to recreate the settings. ( it will create a new 8.0 )
( Some settings are saved in the files under C:\Users\"username"\AppData\Local\Unigraphics Solutions\NX80 but not all.)
* In case this doesn't help, you can restore the renamed registry key. If it does help you can delete the renamed registry key.
Tomas
After a day trying/testing i put the old 8.0 back.
The Assembly Navigator keeps jumping back everytime i switsch between moddeling, sheetmetal, drafting and sometimes when i start some functions.
But thankls for your answer Tomas.
If you put it on your number 1 monitor you should be ok.
You should be able to set what monitor is your number 1 in Windows.
I'll try this over a week, when i'm back at office.
No, i had NX on monitor 1 and the part and assembly navigator on monitor 2.
But now i changed that as a test.
And NX stay's perfect on monitor 2, but the part and assembly navigator still don't stay at the same place.
But it's a small improvement because they stay at monitor 1 and don't jump to the other screen. So this is a bit less irritating.
Mark Rief
Product Manager
Siemens PLM
And what is GTAC?
Greatings,
http://support.industrysoftware.automation.siemens...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
