Bondary conditions (rotation without translation)
I am relatively new to solidworks simulation so maybe I am asking something quite obvious but any help would be appreciated. The model I am working on can be seen in attached image. I am trying to do a linear analysis, taking into account uneven supports.
[url=http://postimage.org/image/vmsuacowh/]
[/url]
Load is continuous, but indicated with one arrow for direction only
On the left side no translation is allowed, and rotation is allowed only about support axis (hinge)
Right side should allow translation along longer axis of construction, allow rotation about support axis, and additionally should account for "a" degrees torsional deflection.
The problem I come up with is when I set up a constraint I cannot have the support and torsional deflection at the same time. I can set up deflection angle, but I have to allow translation thereby loosing support from that side of construction.
Any help in the right direction would be helpful.
[/url]Load is continuous, but indicated with one arrow for direction only
RE: Bondary conditions (rotation without translation)
Although maybe I can apply rotating boundary condition and put an aligned virtual plate under it. I will try and be back when I have some idea of the results.
