Socket Weld Fitting Class and Pipe Schedule
I am new here, please go easy on me.
I'll pose the question first. What class fitting to use with sched 160 pipe and system pressure at 3000psi?
I work in a Hot strip mill for a global steel producer. We have a 3000psi water system that is used to penetrate water underneath the scale of the hot strip. I am upgrading a couple strainers that go before our valves. The old strainers have a 3" backwash line that comes off the main pressure header. I want to cut and cap this line, because it is not needed with my new strainers. I am having trouble though with figuring out what class of fitting to use. I know the 3000 class isn't for 3000 psi service, but have read that the 6000 class fittings are rated at that class with the use of sched 160 pipe.
Thanks, your help is much appreciated
Brent
Brent
RE: Socket Weld Fitting Class and Pipe Schedule
Independent events are seldomly independent.
Thanks everyone for the quick responses.
You should be aware of a few things.
- B16.11 recommends Class 9000 fittings for certain pressures/temperatures and materials. ( I don't lnow if you are in this range for this class of fitting
- Personally, I would not close the 3" NPS piping system with a socket welded fitting. I would use a schedule 160 cap.
