Square Piping for Fluid Conveyance
Does anyone have any experience with using non-circular pipe for fluid conveyance? More specifically, square or rectangular cross section. Maybe you know of some reference material that exists.
The only standard I could find is ASME Section VIII - Division I - Mandatory Appendix 13, which is 'Vessels of Noncircular Cross Section'. However, I don't think this is appropriate.
Thanks in advance.
Thanks in advance.
RE: Square Piping for Fluid Conveyance
What do you gain?
There are (almost) NO fittings, valves or supports available, so your "economy" of square pipe had better be very, very compelling.
Internal pressure constrains against high "square pipe" fluid pressures. Again, no explicit reason why you could not require square pipe, but there are almost reasons to use it.
If you use hydraulic radius (diameter)(4A/P), then you can use most of the formulaes for flow with circular section.
Independent events are seldomly independent.
Channels are commonly used for civil projects such as dams, etc. You can use the standard hydraulic formulas.
Here is a link to the Hazen Williams formula for non-circular conduits:
http://www.calctool.org/CALC/eng/civil/hazen-willi...
racookpe1978, you make a valid point. Let's just assume that the benefit I gain outweighs the additional costs.
To be more specific, we are thinking of using it for a steam line with a design pressure of 145psi. The concern is using a non-circular cross section in a pressure situation. I can't find any design standards for this application.
Ted
Again, it is your decision, you need to justify the extra expense as well as the loss of safety margins to your client.
Do yourself a favor. Stick with circular pipe. There's a reason people use it, as hytools alluded to.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
