Non normalised 5120h gears
Does anyone have any experience with removing the normailizing process for rough forging stock for gears (5120h material or something similar) prior to green operations (turning, deburring, hobbing, spline rolling etc).
A proposal has been put forward to remove the normalizing process and send gear rough stock directly to our factory after hot forging. Removal of normalization will give a significant cost saving and i am aware of other people who have done this in the past.
Is this advisable?
Would you expect to see any adverse effects in green end operations due to the fact the the non normalised stock will have a higher core hardness.
Is this advisable?
RE: Non normalised 5120h gears
distortion after quenching (more distortion, potential quench cracks)
hardness after quenching (soft spots)
tool life in turning, hobbing, and spline rolling operations (reduced tool life in all of these)
surface roughness after machining operations
Lastly, I would point out that industry guidelines, like those published by AGMA, highly recommend normalizing alloy steels prior to initial machining operations. And the guidelines used in aeropsace, such as AMS 2759, typically make it a mandatory step.
Terry
I have to question this statement. The cost of normalizing is just not that great. For a 5 pound gear, you're looking at 25 cents or so. Considering the overall cost of the gear, that really isn't that significant. While I understand that if you are looking at 500,000 of these gears, that's $125,000, which may seem like a significant amount, but considering the cost of 500,000 gears is probably $5 million, that $125,000 isn't really that significant. If you compare that $125,000 to the sale price of those 500,000 gears, you will find it really is insignificant.
When you give further consideration to the cost of the additional problems, as is mentioned above, any savings goes away. Just an increase in scrap rate of 1% could cut that number by nearly half. When you consider the cost of the change can be considerably larger than just a increase in scrap rate (increase rework, missed deliveries, lower product quality), chaniging the process can be taking a pretty big chance for a somewhat small return.
rp
