Quarter circle structured mesh. Can't mesh tickness with just one layer of elements. HELP.
Good afternoon,
I want mesh a quarter blank with 1mm, and i try to mesh along thickness with just one layer of elements.
When i use a structured mesh, despite i seed the corners of the blank with one element, when i mesh the part appear with two layers.
Anybody can help me and said why this appens??
Look behind to see better details,
How can be seen the mesh has two elements to thickness and i just want one.
How can i do?
How can i do?
RE: Quarter circle structured mesh. Can't mesh tickness with just one layer of elements. HELP.
Select ALL of edges along the thickness and seed by the number of elements, not by the seed size.
Try to do the geometry a make a mesh and you can see what i'm said.
Change mesh controls (Assign mesh controls) to either sweep or bottum-up technique to achieve what you want.
If anyone knows why this appeans please contact.
Try to divide your part(Tools->Partition->Cell), see Picture below, and then mesh your part.
So to conclude, just works if partition mode is used, right?
I cant undertand why just doent work without partition.
I'm using sweep mesh, with this feature i perform what i want, but i continue to no understand the reason why this appeans, maybe a bug of Abaqus.
Thank you for helping!
I'm meshing a similar geometry.
My problem is in creating parts, I cannot obtain the three parts highlighted in the figure.
I've tried the different techniques to divide this quarter of circular blank and I've looked into the example manual, but no clear help I found.
Any tip will be appreciated.
