Adding a picture to surface or plane in modeling, NX7.5
I'm trying to find a solution to adding a picture to a surface or plane in UG NX7.5.
Is this possible?
RE: Adding a picture to surface or plane in modeling, NX7.5
yes look for the decal option. view -> visulization -> decal
After it's applied, shouldn't it display? I have tried multiple times, but it's not showing up.
It does, however, show up as a material in Resource_Bar-> Materials_in_part.
Are you using STUDIO DISPLAY for rendering? I hope you are not using shaded mode.
Best Regards
Kapil Sharma
Nope, I don't have the studio display available. Is it not possible with shaded display?
How to display in (master model) drawing view?
'Decals' only show when using Studio Display, which is not supported on a drawing. The best you can do for a drawing is to capture an image, such a jpeg, while you're in Studio mode and then add it as an 'Image' to your drawing sheet.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
