Gear Pump supplier
Gear Pump supplier
Dear All.
I am looking for a trustworthy supplier of a gear pump working with crude oil bottoms (like an asphalt) which are 330°C (theese bottoms have a lower viscosity than water at this temperature)and under high vacuum on the headspace of the tank supplying the pump (3 mBar abs, so very little NPSH is availble. this has to be a gasket less aplication with ceramic bearings.
I already know Witte pumps from Germany... any other idea of a good supplier for this type of equipment?
thank you
Marcelo Velez
thank you
Marcelo Velez
RE: Gear Pump supplier
I agree with micalbrch's recommendation. Roper's specialty is heavy-duty gear pumps for heavy and viscous petroleum-based liquids. They make a good pump and their reputation is based on their performance. Go to:
http://www.roperpumps.com/roperpumps/ProductsTax.a...
