typical p. drop per meter/foot ?
For what typical pressure drop per unit of lenght in water pipes are desingned air heating/ cooling systems ?
RE: typical p. drop per meter/foot ?
The headloss will be approximately 5-6 psi per 100 ft of pipe. If you use high velocities, you may create noise issues.
Thank you !
So, like in air ducts - with the ratio of water to air densities.
