Wind Application with a fabric.
Dear Group,
I have what I consider an unique structural problem. It basically involves two steel rods that are attached to a wall in the hortizontal, one on top of each other (approximately 50 " apart and the rods are 37" wide. The two rods are attached at each end in a bracket that allows rotation. The steel rods are connected by a fabric. The fabric is stretch by rotating the top rod with a ratchet to tigthten fabric like a drum. I have been trying to size the rod since I need to consider all the forces on the rod. This fabric is subjected to wind and is solid.
------------------------------- Rod
-------------------------------- Rod
Any help would be greatly appreciated in determining the forces and how they would be acted upon the steel rod.
Thanks.
Thanks.
RE: Wind Application with a fabric.
It is hard to explain, but that is it in a nutshell.
If you assumed that the fabric was just a slab spanning onto beams it would give you a basic load & moment giving, say, a 1.5" tube or bar. Look at the stress & deflection & take a view. Problems like these are half calculation to see if you are in the right order & half judgement on top of that.
