Varying pressure load
I m trying to simulate a model which involves two identical shell surfaces where their lower ends cannot move and a pressure is applied on them.
The positive pressure closes the gap between the shells and a contact occurs between them.
My probelm is that when i m trying to use varying pressure the model doesnt run while it is running for a pressure defined by 'ramp'. In any way both pressures are about the same magnitudes.
The mode of calculation is 'Static General'.
Any help would be very much appreciated
Iftah
Iftah
RE: Varying pressure load
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
