how to analyse undercuts
My collegue ,doing tooling, wants to know how to analyse undercuts?
sorry new in NX
regards
Erwin
RE: how to analyse undercuts
Although you can utilize draft analysis to give a cursory check but there are some OOTB also like for example you can check it through MOLD PART VALIDATION also which shows undercuts seperately.
Best Regards
Kapil Sharma
Any smaller solution?
sorry new in NX
regards
Erwin
do you have any sample part with you? One very crude option may be using EXTRACT BODY (REGION OF FACES) and use ANGULAR TOLERANCE of 90 degrees (or more) in the USE TRAVERSE TANGENT EDGE ANGLE .Select any Prting surface first and then try running this.
For simple models it will surely give you some hints.Let us try it out on some sample ones.
Best Regards
Kapil Sharma
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
slope face analysis did the trick with a lower license
sorry new in NX
regards
Erwin
