Fatigue in Abaqus
Fatigue in Abaqus
Hello everyone,
How could I estimate the fatigue life of a mechanical part under cyclic loading using Abaqus ? I don't have enough informations about fatigue under abaqus.
Thank you very much
Thank you very much
RE: Fatigue in Abaqus
It is possible with VCCT and it might be with xFEM. Search for "low-cycle fatigue" in the manual. In any case it would require some hard to get material parameters and in the case of VCCT prior knowledge of the crack path. Its no easy topic. If you have time and are serious, than check out the publications by Turon et al. They are researching a cohesive element based fatigue prediction. They have quite promising intermediate results. If you are good with user written subroutines, you can build your own fatigue-including cohesive element based on the works of Turon et al. But be warned, it takes plenty of computational resources and patience on your side. Its still an active field of research.
