Filter options in Nx
Hello all,
I have been using the filter option frequently in modelling & drafting.
As there are variety of filters available, is it possible to remove some of them from the list (or customize the list) just to avoid unwanted scrolling up & down.
http://files.engineering.com/getfile.aspx?folder=2...
Sundeep
Nx 7.5.4.4
Sundeep
Nx 7.5.4.4
RE: Filter options in Nx
That being said, if you feel that it tedious to continuously expand and select a object/item type as a filter, perhaps you should learn to properly use the QuickPick tool since this will allow you to easily select the objects/items that you wish to pick without having to set explicit filters but rather filter only the possible objects that could have been selected at the moment that you pressed MB1. I think that you will find that over the longhaul gaining the skill to use this workflow will prove to be very productive and much less tedious than continuously setting and unsetting selection filters.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
