Low voltage replacement for 74HC74 circuit
I'm working in a tight space envelope (about the size of a AAA battery) and need a momentary switch to latch on/off a tiny motor. In order to conserve on parts and assembly, I was going to use a 74HC74 (http://www.nxp.com/documents/data_sheet/74HC_HCT74...) turn my circuit on and off and keep it that way until I hit the momentary switch again.
However, the 74HC74 has a minimum voltage supply of 2v while I am restricted to using 1.2v AAA batteries. I'm quite a layman groping in the dark here, but how would I go about finding a similar/identical circuit for use on a lower voltage?
I am adapting the design from here: http://www.discovercircuits.com/DJ-Circuits/onoffw...
Although, my understanding is that I can remove most of the extra parts and have the 74HC74 do all of the work (as a latching switch).
RE: Low voltage replacement for 74HC74 circuit
Datasheet here:
http://www.toshiba-components.com/docs/logic/TC74V...
Benta.
