ANSYS Composite Material Design
I am Preparing a midship section by using the Ansys for a composite material boat, I am using Shell 181 for the hull shell & Solid 185 for the foam core stiffeners , shall I used a contact between the hull shell 181 & Solid185 or there is a way to glue them together?
