journal IO.file.delete
I am having trouble using a IO.File.Delete command within NX's journal. The error message I keep receiving is attached. This is a part of a bigger program that creates a "_rev" version of my current workpart. There is an intermediate part "delete_rev”, which I need to manually go through and delete files but I would like to automate this. The following snippet is what I plan to add to the code but for some reason cannot delete the "delete_rev" part from NX. I can however delete the "_rev" and original part but that doesn't help me automate this.
Additional snippet:
CODE --> vb
Module NXJournals
Sub Main
Dim theUI As UI = UI.GetUI()
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workpart As Part = theSession.Parts.work
Dim Revcomp As String
        Revcomp = path.GetFileNameWithoutExtension(workPart.FullPath)
        Dim folderName As String = Path.GetDirectoryName(workpart.FullPath)
        Dim fullpathname2 As String = folderName & "\" & "delete_" & Revcomp & ".prt"
'delete
If IO.File.Exists(fullpathname2) Then
MsgBox("Deleting.")
 IO.File.Delete(fullpathname2)
                End If
End Sub
End Module
Original Code
CODE --> vb
Option Strict Off
Imports System
Imports System.Windows.Forms
Imports System.IO
Imports System.Collections.Generic
Imports System.Drawing
Imports System.Threading
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
Sub Main
Dim lw As ListingWindow = theSession.ListingWindow()
Dim partname As String
Dim disp_partname As String
Dim displayPart As Part = theSession.Parts.Display
Dim comp As String
Dim insert as String
Dim partLoadStatus2 As NXOpen.PartLoadStatus = Nothing
 partname = path.GetFileNameWithoutExtension(workPart.FullPath)
comp = partname
         insert = "__Prep"
        'Revcomp = comp .insert(5, insert)
Dim dIndex = comp.IndexOf("_")
Revcomp=comp.insert(dIndex, insert)
'To find folder name and such
        Dim fullpathname1 As String = "C:\Program Files\UGS\NX 7.5\UGII\html_files/model_template_inch.prt"
If File.Exists(fullpathname2 & ".prt") Then
If Msgbox("File Already Exists. Do you want to overwrite?", vbyesno + vbquestion, "File Already Exists") = vbno then
Exit Sub
Else
fullpathname2 = fullpathname2 & "_"
End If
End If
'Msgbox(comp & chr(13) & Revcomp)
            Dim partLoadStatus3 As PartLoadStatus
            Dim status1 As PartCollection.SdpsStatus
            status1 = theSession.Parts.SetDisplay(displaypart, False, True, partLoadStatus3)
            workPart = theSession.Parts.Work
            displayPart = theSession.Parts.Display
            partLoadStatus3.Dispose()
            'Msgbox(partname)
Fullpathname2 = fullpathname2 & ".prt"
        File.Copy(fullpathname1, fullpathname2)
        Dim basePart1 As BasePart = theSession.Parts.OpenBase(fullpathname2, partLoadStatus2)
        Dim part2 As Part = CType(basePart1, Part)
        Dim basePoint1 As Point3d = New Point3d(0.0, 0.0, 0.0)
        Dim orientation1 As Matrix3x3
        orientation1.Xx = 1.0
        orientation1.Xy = 0.0
        orientation1.Xz = 0.0
        orientation1.Yx = 0.0
        orientation1.Yy = 1.0
        orientation1.Yz = 0.0
        orientation1.Zx = 0.0
        orientation1.Zy = 0.0
        orientation1.Zz = 1.0
        Dim component1 As Component = workpart.ComponentAssembly.AddComponent(part2, "Model", Revcomp, _
                                                         basePoint1, orientation1, 200, partLoadStatus2)
Dim partSaveStatus1 As PartSaveStatus
Dim partLoadStatus1 As PartLoadStatus
theSession.Parts.SetWorkComponent(component1, partLoadStatus1)
partLoadStatus1.Dispose()
Dim fullpathname3 As string
fullpathname3=folderName & "\" & Revcomp & ".prt"
If File.Exists(fullpathname3) Then
fullpathname3=foldername & "\" & Revcomp & "_.prt"
End If
'Msgbox(fullpathname2)
partSaveStatus1 = workPart.SaveAs(fullpathname3)
partSaveStatus1.Dispose()
        Dim mySolid As NXObject
        If SelectSolid("Select a solid", mySolid) = Selection.Response.Cancel Then
            Exit Sub
        End If
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
        Dim nullFeatures_Feature As Features.Feature = Nothing
        If Not workPart.Preferences.Modeling.GetHistoryMode Then
            Throw (New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
        End If
        Dim waveLinkBuilder1 As Features.WaveLinkBuilder
        waveLinkBuilder1 = workPart.BaseFeatures.CreateWaveLinkBuilder(nullFeatures_Feature)
        Dim extractFaceBuilder1 As Features.ExtractFaceBuilder
        extractFaceBuilder1 = waveLinkBuilder1.ExtractFaceBuilder
        extractFaceBuilder1.FaceOption = Features.ExtractFaceBuilder.FaceOptionType.FaceChain
        waveLinkBuilder1.Type = Features.WaveLinkBuilder.Types.BodyLink
        'waveLinkBuilder1.CopyThreads = False
        extractFaceBuilder1.ParentPart = Features.ExtractFaceBuilder.ParentPartType.OtherPart
        theSession.SetUndoMarkName(markId1, "WAVE Geometry Linker Dialog")
        extractFaceBuilder1.Associative = True
        extractFaceBuilder1.FixAtCurrentTimestamp = False
        extractFaceBuilder1.HideOriginal = False
        extractFaceBuilder1.InheritDisplayProperties = False
        Dim selectObjectList1 As SelectObjectList
        selectObjectList1 = extractFaceBuilder1.BodyToExtract
        'extractFaceBuilder1.CopyThreads = False
        Dim added1 As Boolean
        added1 = selectObjectList1.Add(mySolid)
        Dim nXObject1 As NXObject
        nXObject1 = waveLinkBuilder1.Commit()
        theSession.SetUndoMarkName(markId1, "WAVE Geometry Linker")
        waveLinkBuilder1.Destroy()
End Sub
   Function SelectSolid(ByVal prompt As String, ByRef selObj As NXObject) As Selection.Response
        Dim title As String = "Select a solid"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal arg As String) As Integer
        Return CType(Session.LibraryUnloadOption.Immediately, Integer)
    End Function
End Module
Denis Huskic
Data Prep
Kettering University
Class of '17
RE: journal IO.file.delete
The error message is telling you that you don't have privileges to delete the file. Either you do not have ownership of the file, it is in use by the system and "locked" (possible if your journal creates the file, does something with it and tries to delete it without closing it first), or the file or one of its parent folders is marked as "read only". It looks like you are copying a template part and renaming it for your purposes, so it is probably the ownership issue and/or the file is marked as read-only.
p.s.
It may not be a problem, but I don't recommend mixing forward and backward slashes when referencing a file path.
CODE
www.nxjournaling.com
I agree 100% with that last note, quiet embarrassing on my end. You read the journal correctly, I copy a template, rename it to match the work part with a slight revision and then link over that body. Next, I attempted to delete an extra file that was created in the process, this is where I struggle. I tried to take into account the fact that the file could be locked. I read that creating a second module for the journal would help solve this, obviously this may not be true. Could you offer any insight on "unlocking" it? I am trying to move it to another directory and then attempt to delete it but that is proving to be a dead end as well.
Denis Huskic
Data Prep
Class of '17
I figured it out! It was locked because it was marked as a "read-only" file. I just put a small snippet into the code before I tried the delete command and it works just fine now. I'll be sure to keep this in mind for future journals. Here is the code, keep in mind I did some additional edditing so the path names might not match:
CODE --> vb
IO.File.SetAttributes(fullpathname3, IO.FileAttributes.Normal)
IO.File.Delete(fullpathname3)
Denis Huskic
Data Prep
Class of '17
