Missing window for Measure command
I have lost the window that should pop up when you use the measure command in Catia V5 R19. The command still works and I get the output in the green on screen box but no command window. The thickness measure command works as normal.
I have restored my settings from a back up file so I can work OK but that file was not fully up to date so rather than re-do the changes to my settings I wondered if there is a way of switching a command window display on or off that could be done in error? I usually keep the tool bars locked.
