Thermal loads
Thermal loads
I've looked through the help, and website, and google.
How does RISA account for joint thermal loads? Can these be factored per ASCE in the TL basic load case? It doesn't seem there's a way to input a joint temperature and associate it with a load case.
I've been using the T uniform loads, which can be applied to a load case, but I would like to compare the results of a beam uniform temperature load to the results of the two beam nodes being at an elevated temperature.
Also, is there a way to apply joint temperatures without clicking on every joint and applying the load one at a time?
RE: Thermal loads
You can use the joint spreadsheet to apply thermal loads to multiple joints in lieu of clicking on them individually.
RE: Thermal loads
