joining curves in autodesk inventor
Hi everyone!
Is there a way we can join curve segments to make it one in autodesk inventor?
(I'm trying to create curves with multiple segments but the result after extrusion(surface) has lot of adjoining faces)
Thanks for your help.
Cgelang
Cgelang
RE: joining curves in autodesk inventor
That was a general solution that would have required adaption to your problem, sounds like you are looking for a specific solution.
In fact, now that I re-read your problem description there seems to be a contradition in terms.
Time to attach your ipt file here.
