Cutting issues, Bystronic 4kw: holes missing and sometimes side of the part
we meet a problem on our 4kw Bystronic. Sometime the machin doesnt cut the holes, and even the side of the piece which should be cutted.
We can see the moving of the head but the machin doesn't cut (like no laser beam).
At the beginning of this issue (already 2 or 3 years ago), we just knew that the machine was missing some hole maybe 2 or 3 times a year. Bystronic said that it was a problem of software, so we upgrade it but now the problem appear more an more often. SOmetime once a day, then duraing 1 week no problem, then appear again.
Then 3 or 4 monts ago, we can see that the machin doesnt cut also some side of the parts (new symptom).
We already change many card with bystronic but still the same.
Bystronic ask us to make a RAMDUM (when the problem appear). So it means the operator has to stay in front of the machine and when he see the problem appear, make the RAMDUM. So, we save 2 times the files and send it to Bystronic Swiss but still on investigation.
Do you have any idea?
Best regards
Yannick
Best regards
Yannick
RE: Cutting issues, Bystronic 4kw: holes missing and sometimes side of the part
-HR
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
